Ga door naar hoofdinhoud
iView-776TPCII Rear Panel Replacement
Wat je nodig hebt
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: stap 1, afbeelding 1 van 3 iView-776TPCII Rear Panel Replacement, Rear Panel: stap 1, afbeelding 2 van 3 iView-776TPCII Rear Panel Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
    Vraag FixBot
    Voeg opmerking toe
  2. iView-776TPCII Rear Panel Replacement: stap 2, afbeelding 1 van 2 iView-776TPCII Rear Panel Replacement: stap 2, afbeelding 2 van 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jonathan Fenimore
314 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Baechle Fall 2015 Lid van IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 45
Altijd: 724
