Ga door naar hoofdinhoud
iVIEW-754TPC Camera Assembly Replacement
Wat je nodig hebt
    1. iVIEW-754TPC Camera Assembly Replacement, Rear Panel: stap 1, afbeelding 1 van 3 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: stap 1, afbeelding 2 van 3 iVIEW-754TPC Camera Assembly Replacement, Rear Panel: stap 1, afbeelding 3 van 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Vraag FixBot
      Voeg opmerking toe
    1. iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: stap 2, afbeelding 1 van 3 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: stap 2, afbeelding 2 van 3 iVIEW-754TPC Camera Assembly Replacement, Camera Assembly: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • The camera module is located directly under the top right corner of the back cover.
      • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
      • As you peel the tape backward, the front facing camera may come out, this is not an issue.
      • If the front facing camera does not come out, gently lift it out with a pair of tweezers
      Vraag FixBot
      Voeg opmerking toe
    2. iVIEW-754TPC Camera Assembly Replacement, Remove Camera: stap 3, afbeelding 1 van 2 iVIEW-754TPC Camera Assembly Replacement, Remove Camera: stap 3, afbeelding 2 van 2
      • Use a spudger to lift flap on top of the camera ZIF adapter.
      • At this point the camera module can be easily removed with a pair of tweezers.
      • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Robert Clark
1.065 Reputatie
7 handleidingen geschreven
USF Tampa, Team 5-4, Brown Winter 2015 Lid van USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 512
