Ga door naar hoofdinhoud
iVIEW-754TPC Battery Replacement
Wat je nodig hebt
    1. iVIEW-754TPC Battery Replacement, Rear Panel: stap 1, afbeelding 1 van 3 iVIEW-754TPC Battery Replacement, Rear Panel: stap 1, afbeelding 2 van 3 iVIEW-754TPC Battery Replacement, Rear Panel: stap 1, afbeelding 3 van 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Vraag FixBot
      Voeg opmerking toe
    1. iVIEW-754TPC Battery Replacement, Remove Battery: stap 2, afbeelding 1 van 3 iVIEW-754TPC Battery Replacement, Remove Battery: stap 2, afbeelding 2 van 3 iVIEW-754TPC Battery Replacement, Remove Battery: stap 2, afbeelding 3 van 3
      • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
      • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
      Vraag FixBot
      Voeg opmerking toe
    1. iVIEW-754TPC Battery Replacement, Desolder wires: stap 3, afbeelding 1 van 3 iVIEW-754TPC Battery Replacement, Desolder wires: stap 3, afbeelding 2 van 3 iVIEW-754TPC Battery Replacement, Desolder wires: stap 3, afbeelding 3 van 3
      • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
      • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
      • To ease reassembly, take note of which wire goes to the negative and positive terminals.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
calvin
188 Reputatie
1 Handleiding geschreven
USF Tampa, Team 5-4, Brown Winter 2015 Lid van USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 2,813
