Inleiding
This guide will teach someone how to access and remove the screen display of their iRulu AX760. In following this guide you will learn how disconnect and replace the screen display.
Wat je nodig hebt
Use a plastic opening tool or metal spudger to free the rear cover.
Insert your spudger into the side of your tablet.
Crack open each edge and remove the cover.
Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
Keep the wires of the battery taught.
The iron should only be pressed to the solder for 2-3 seconds max.
Visit this link for information about soldering. Hoe moet je (de-)solderen?
Use the plastic spudger to pry the tabs open on the digitizer ribbon sockets.
Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
Één andere persoon heeft deze handleiding voltooid.
