Ga door naar hoofdinhoud
iRobot Roomba 880 Cleaning Head Replacement
Wat je nodig hebt
  1. iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: stap 1, afbeelding 1 van 3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: stap 1, afbeelding 2 van 3 iRobot Roomba 880 Cleaning Head Replacement, Cleaning Head: stap 1, afbeelding 3 van 3
    • Flip the Roomba over, wheel-side up.
    • Using a Phillips #1 screwdriver, loosen the four 15 mm screws illustrated. Two are located on the battery door, while two are on the bottom panel.
    • Remove the battery door, pulling straight up from the two indents above the screws.
  2. iRobot Roomba 880 Cleaning Head Replacement, Side Brush: stap 2, afbeelding 1 van 2 iRobot Roomba 880 Cleaning Head Replacement, Side Brush: stap 2, afbeelding 2 van 2
    • Using a flat head screwdriver, loosen the screw on the top of the side brush.
    • Remove side brush.
    • The bottom panel cannot be removed without first removing the side brush, so make sure to do this first.
  3. iRobot Roomba 880 Cleaning Head Replacement, Bottom Panel: stap 3, afbeelding 1 van 1
    • Pull up on the bottom panel to remove.
  4. iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: stap 4, afbeelding 1 van 2 iRobot Roomba 880 Cleaning Head Replacement, Dust Bin: stap 4, afbeelding 2 van 2
    • Reach underneath the dust bin, press the bin removal button, and pull out.
    • The bin removal button is located on the top edge of the bin.
  5. iRobot Roomba 880 Cleaning Head Replacement: stap 5, afbeelding 1 van 2 iRobot Roomba 880 Cleaning Head Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the four 10 mm screws shown.
  6. iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: stap 6, afbeelding 1 van 3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: stap 6, afbeelding 2 van 3 iRobot Roomba 880 Cleaning Head Replacement, Remove Cleaning Head: stap 6, afbeelding 3 van 3
    • Remove the cleaning head by grabbing the two protruding tabs as shown, and pulling straight up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Allie Ahern
130 Reputatie
1 Handleiding geschreven
Cal Poly, Team S17-G4, Banghart Spring 2017 Lid van Cal Poly, Team S17-G4, Banghart Spring 2017
CPSU-BANGHART-S17S17G4
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 59
Altijd: 2,648
