Inleiding
This guide will go over how to clean or replace the wheels in your iRobot Roomba 805. If you plan on replacing either wheel you can get a new one from iRobot. A Phillips head screwdriver is needed to follow this guide.
Wat je nodig hebt
Remove the battery panel, then remove the two screws behind the wheels, and lift the bottom panel apart from the rest of the device.
Één andere persoon heeft deze handleiding voltooid.
