Inleiding
Learn how to easily replace a broken wheel on your Roomba 650. The two main wheels move the Roomba forward, as opposed to the caster wheel in the front which changes direction. Sometimes dusts get trapped inside the wheel, so just gently push the wheel up and down to shake off any debris in there as opposed to replacing them.
Wat je nodig hebt
With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
Set the screw aside and pull the brush out.
Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
Remove the wheels by pulling them out.
4 andere personen hebben deze handleiding voltooid.
