Ga door naar hoofdinhoud
iRobot Roomba 650 Caster Wheel Replacement
Wat je nodig hebt
    1. iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: stap 1, afbeelding 1 van 2 iRobot Roomba 650 Caster Wheel Replacement, Removing the Side Brush: stap 1, afbeelding 2 van 2
      • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
      • Set the screw aside and pull the brush out.
      Vraag FixBot
      Voeg opmerking toe
    2. iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: stap 2, afbeelding 1 van 2 iRobot Roomba 650 Caster Wheel Replacement, Bottom Panel Removal: stap 2, afbeelding 2 van 2
      • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
      • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
      • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
      Vraag FixBot
      Voeg opmerking toe
    1. iRobot Roomba 650 Caster Wheel Replacement, Caster Wheel: stap 3, afbeelding 1 van 1
      • Begin by pulling on the caster wheel. It should pop out of its housing fairly easily.
      Vraag FixBot
      Voeg opmerking toe
    2. iRobot Roomba 650 Caster Wheel Replacement: stap 4, afbeelding 1 van 2 iRobot Roomba 650 Caster Wheel Replacement: stap 4, afbeelding 2 van 2
      • Once caster wheel is off the Roomba, push on the wheel so that it slides out of the groves it sits in.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Alex Schnorr
649 Reputatie
3 handleidingen geschreven
Cal Poly, Team 19-7, Maness Winter 2015 Lid van Cal Poly, Team 19-7, Maness Winter 2015
CPSU-MANESS-W15S19G7
4 Leden
12 handleidingen geschreven
3Gids Commentaar
Alternate instructions.
1. skip steps 1 and 2. you don't need to take the panel off to remove the caster wheel.
2. follow steps 3 and 4.
Matt Johnson - Antwoord Deel
Worked for my 690 as well.
Luke Oliver - Antwoord Deel
Hi, my caster wheel drops out easiy from the groves… a bit like the groves are worn out already and are no longer able to hold the wheel metal spoke in place. I would like to know if this can be fixed without resorting to buying a new wheel? (Reduce, Reuse, Recycle) Please help?
Rykel Lim - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 32
Altijd: 2,701
