Ga door naar hoofdinhoud
iRobot Roomba 560 Fan Replacement
Wat je nodig hebt
    1. iRobot Roomba 560 Fan Replacement, Fan: stap 1, afbeelding 1 van 1
      • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
      Vraag FixBot
      Voeg opmerking toe
    2. iRobot Roomba 560 Fan Replacement: stap 2, afbeelding 1 van 2 iRobot Roomba 560 Fan Replacement: stap 2, afbeelding 2 van 2
      • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
      • Remove the top of the vacuum bin by pulling it straight up.
      • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
      Vraag FixBot
      Voeg opmerking toe
    3. iRobot Roomba 560 Fan Replacement: stap 3, afbeelding 1 van 3 iRobot Roomba 560 Fan Replacement: stap 3, afbeelding 2 van 3 iRobot Roomba 560 Fan Replacement: stap 3, afbeelding 3 van 3
      • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
      • Remove the casing that surrounds the fan by pulling it straight up.
      • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
      Vraag FixBot
      Voeg opmerking toe
    4. iRobot Roomba 560 Fan Replacement: stap 4, afbeelding 1 van 3 iRobot Roomba 560 Fan Replacement: stap 4, afbeelding 2 van 3 iRobot Roomba 560 Fan Replacement: stap 4, afbeelding 3 van 3
      • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
      • Remove the casing from the fan and battery component by pulling it straight up.
      Vraag FixBot
      Voeg opmerking toe
    5. iRobot Roomba 560 Fan Replacement: stap 5, afbeelding 1 van 1
      • Remove the small black button from the top of the battery.
      • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
TJ Tamura
289 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-22, Maness Fall 2015 Lid van Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 48
Altijd: 5,273
