Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide explains how to remove the main brush motor from your Roomba.
Wat je nodig hebt
Push on the dirt bin release button, and pull gently.
Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
Repeat for the opposite side of the brush case.
