Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Push on the dirt bin release button, and pull gently.
Use a Phillips #1 screwdriver to loosen the 4 captive screws around the case .
Use a Phillips #1 screwdriver to remove the 9.5mm screws from the side of the brush case, and pull to detach.
Repeat for the opposite side of the brush case.
Use a Phillips #1 screwdriver to remove the three 5.0mm screws from the back of the brush case.
Pull off the back of the brush case.
Use a Phillips #1 screwdriver to remove the two 1.5mm screws securing the chip in place.
Remove the chip from its housing in the blue brush case.
Use a Phillips #1 screwdriver to remove the two 5.5mm screws securing the motor in place.
Use a Phillips #1 screwdriver to remove the two 4.5mm screws on the top and bottom of the metal plate.
Pull out the motor and metal covering.
Use a Phillips #1 screwdriver to remove the two 3.5mm screws on the corners of the circuit board.
Gently pull out the circuit board.
