Ga door naar hoofdinhoud
iRobot Braava 320 Battery Replacement
Wat je nodig hebt
    1. iRobot Braava 320 Battery  Replacement, Battery: stap 1, afbeelding 1 van 1
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      Vraag FixBot
      Voeg opmerking toe
    2. iRobot Braava 320 Battery  Replacement: stap 2, afbeelding 1 van 1
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      Vraag FixBot
      Voeg opmerking toe
    3. iRobot Braava 320 Battery  Replacement: stap 3, afbeelding 1 van 2 iRobot Braava 320 Battery  Replacement: stap 3, afbeelding 2 van 2
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
bradley boardwine
222 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G3, Nance Spring 2017 Lid van USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Leden
15 handleidingen geschreven
1Gids Commentaar
where do I get a new battery from?
j.svetlova - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 5,159
