Ga door naar hoofdinhoud
iPod Shuffle 4th Generation Control Buttons Replacement
Wat je nodig hebt
  1. iPod Shuffle 4th Generation Control Buttons Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
    Vraag FixBot
    Voeg opmerking toe
    • Use a heat gun, hairdryer, iOpener, etc. to heat the back of the Shuffle until it's slightly too hot to the touch.
    • If using a heat gun, only apply heat for a few seconds at a time. Check the temperature of the metal - if it gets too hot to handle, let it cool.
    Vraag FixBot
    Voeg opmerking toe
  2. iPod Shuffle 4th Generation Control Buttons Replacement: stap 3, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 3, afbeelding 2 van 2
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
    • There are no clips on the top and bottom of the rear panel. With the Apple logo upright and facing you, all the clips are to the left and right.
    • If you use a metal spudger, you will scratch the housing.
    • You can try to pull on the rear panel by the clip. If you use too much force, you will bend the rear panel. If it feels stuck, stop and heat the glue to soften it.
    Vraag FixBot
    Voeg opmerking toe
  3. iPod Shuffle 4th Generation Control Buttons Replacement: stap 4, afbeelding 1 van 1
    • Remove the rear panel from the Shuffle.
    • There may be a piece of black rubber covering the logic board, or it may come out with the rear panel. This piece is part of a rubber seal that goes around the edges of the rear panel and covers the controls from the inside.
    Vraag FixBot
    Voeg opmerking toe
  4. iPod Shuffle 4th Generation Control Buttons Replacement, Logic Board Assembly: stap 5, afbeelding 1 van 1
    • If present, remove the thin black moisture seal covering the Shuffle's internals.
    • Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
    Vraag FixBot
    Voeg opmerking toe
  5. iPod Shuffle 4th Generation Control Buttons Replacement: stap 6, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use the edge of an iPod opening tool to flip up the retaining flap on the control button cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use a pair of tweezers to gently pull the control button ribbon cable out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  6. iPod Shuffle 4th Generation Control Buttons Replacement: stap 7, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 7, afbeelding 2 van 2
    • Use an iPod opening tool to gently pry the battery off the adhesive securing it to the front case.
    • Lift the battery out of the front case, being sure not to strain its delicate leads.
    Vraag FixBot
    Voeg opmerking toe
  7. iPod Shuffle 4th Generation Control Buttons Replacement: stap 8, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 8, afbeelding 2 van 2
    • Insert the tip of a metal probe into the hole molded into the logic board retainer nearest the logic board.
    • Pry the retainer first away from the front of the front case, then pull it away from the side of the front case.
    • Remove the logic board retainer from the Shuffle.
    Vraag FixBot
    Voeg opmerking toe
  8. iPod Shuffle 4th Generation Control Buttons Replacement: stap 9, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 9, afbeelding 2 van 2
    • Use the edge of an iPod opening tool to push the headphone jack down toward the center of the Shuffle.
    Vraag FixBot
    Voeg opmerking toe
  9. iPod Shuffle 4th Generation Control Buttons Replacement: stap 10, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 10, afbeelding 2 van 2
    • Continue pushing the logic board down away from the top edge of the Shuffle.
    • Pull the logic board out of the front case by the side nearest the ON/OFF button and gently maneuver the headphone jack out of its recess in the front case.
    • Remove the logic board assembly from the Shuffle.
    Vraag FixBot
    Voeg opmerking toe
  10. iPod Shuffle 4th Generation Control Buttons Replacement, Control Buttons: stap 11, afbeelding 1 van 1
    • Remove the following four screws:
    • Two 1.2 mm Phillips screws with large heads.
    • Two 1.6 mm Phillips screws with small heads.
    Vraag FixBot
    Voeg opmerking toe
  11. iPod Shuffle 4th Generation Control Buttons Replacement: stap 12, afbeelding 1 van 2 iPod Shuffle 4th Generation Control Buttons Replacement: stap 12, afbeelding 2 van 2
    • Use an iPod opening tool to pull the control button plate out of the front case.
    • Remove the control buttons from the Shuffle.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
Sam Waiban - Antwoord Deel
just open the clip past where it is suppose to open and it pops right off.
echow2001 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 86
Altijd: 14,272
