Inleiding
Replacing the battery requires a fine tip soldering iron and is a difficult job that only experienced solderers should attempt.
Wat je nodig hebt
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
Insert an iPod opening tool between the bottom bezel and the dock connector.
Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
Peel the hold switch cable from along the edge of the battery and lay it aside. The hold switch cable is not attached to the battery.
Pry the battery off the adhesive securing it to the metal tray on the logic board.
To reassemble your device, follow these instructions in reverse order, while being careful not to damage the iPod.
189 andere personen hebben deze handleiding voltooid.
42Gids Commentaar
There is one small point which is worth a mention here.After disconnnecting the screen by flicking up a little black bit on the ZIF Connector, I went on to open the next ZiF (The Click Switch)
Yes- bits of ZIF connector everywhere.I actually had to examine a new Click Switch circuit carefully to find that this one is different.
Yes - you flick the White bit. Do apple do this just to keep us on our toes?
I have taken the nano apart and started to use a solder iron to remove the old battery. I must have pulled on the battery before fully melting the solder and have pulled off two of the three tabs from the board.
Can this be fixed?
I tried what Bradley suggested because it really seems easier than to solder the new battery to the iPod circuit board, which is really tiny. Still I couldn't do it. The battery pads are very fragile and I had an hard time folding the leads and the battery circuit board so that it looked the way it originally was. This was the part where I failed because afterwards I wasn't able to insert the battery plus the iPod circuit board inside its case again and ended it breaking it.
When I soldered my battery in I first touched the top and bottom of the pads on the new battery with flux and then added a little solder to the top and bottom of the pads. When I put the pads in place I only had to apply a quick touch and it soldered on perfectly.
Overall it was a real pain! :)
