Inleiding
No audio? Replace the headphone jack!
Wat je nodig hebt
Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should open easily.
Remove the 3 silver Philips screws securing the headphone jack to the rear panel.
11 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
When replacing the jack, should you put the copper tape back on the new part?
