Ga door naar hoofdinhoud
iPod 2nd Generation Display Replacement
Wat je nodig hebt
    1. iPod 2nd Generation Display Replacement, Rear Panel: stap 1, afbeelding 1 van 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 2nd Generation Display Replacement: stap 2, afbeelding 1 van 1
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Vraag FixBot
      Voeg opmerking toe
    3. iPod 2nd Generation Display Replacement: stap 3, afbeelding 1 van 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Vraag FixBot
      Voeg opmerking toe
    4. iPod 2nd Generation Display Replacement: stap 4, afbeelding 1 van 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Vraag FixBot
      Voeg opmerking toe
    5. iPod 2nd Generation Display Replacement: stap 5, afbeelding 1 van 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      Vraag FixBot
      Voeg opmerking toe
    6. iPod 2nd Generation Display Replacement: stap 6, afbeelding 1 van 1
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      Vraag FixBot
      Voeg opmerking toe
    1. iPod 2nd Generation Display Replacement, Hard Drive: stap 7, afbeelding 1 van 1
      • Peel up the metallic tape attached to the top of the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 2nd Generation Display Replacement: stap 8, afbeelding 1 van 1
      • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
      Vraag FixBot
      Voeg opmerking toe
    3. iPod 2nd Generation Display Replacement: stap 9, afbeelding 1 van 1
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      Vraag FixBot
      Voeg opmerking toe
    1. iPod 2nd Generation Display Replacement, Hard Drive Cable: stap 10, afbeelding 1 van 1
      • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
      • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 2nd Generation Display Replacement: stap 11, afbeelding 1 van 1
      • Slide the hard drive cable out of its connector.
      Vraag FixBot
      Voeg opmerking toe
    1. iPod 2nd Generation Display Replacement, Display: stap 12, afbeelding 1 van 1
      • Lift the blue hard drive mounting bracket out of the iPod.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 2nd Generation Display Replacement: stap 13, afbeelding 1 van 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Vraag FixBot
      Voeg opmerking toe
    3. iPod 2nd Generation Display Replacement: stap 14, afbeelding 1 van 1
      • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
      • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. iPod 2nd Generation Display Replacement: stap 15, afbeelding 1 van 1
      • Remove the 8 T6 Torx screws from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    5. iPod 2nd Generation Display Replacement: stap 16, afbeelding 1 van 1
      • Lift the logic board up enough to disconnect the orange touch wheel cable.
      • Lift the logic board out of the iPod.
      Vraag FixBot
      Voeg opmerking toe
    6. iPod 2nd Generation Display Replacement: stap 17, afbeelding 1 van 1
      • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
      Vraag FixBot
      Voeg opmerking toe
    7. iPod 2nd Generation Display Replacement: stap 18, afbeelding 1 van 1
      • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
      Vraag FixBot
      Voeg opmerking toe
    8. iPod 2nd Generation Display Replacement: stap 19, afbeelding 1 van 1
      • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
      • Lift the display off the logic board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 42
Altijd: 8,360
