Ga door naar hoofdinhoud
iPod 1st Generation Logic Board Replacement
Wat je nodig hebt
    1. iPod 1st Generation Logic Board Replacement, Rear Panel: stap 1, afbeelding 1 van 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 1st Generation Logic Board Replacement: stap 2, afbeelding 1 van 1
      • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Vraag FixBot
      Voeg opmerking toe
    3. iPod 1st Generation Logic Board Replacement: stap 3, afbeelding 1 van 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Vraag FixBot
      Voeg opmerking toe
    4. iPod 1st Generation Logic Board Replacement: stap 4, afbeelding 1 van 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Vraag FixBot
      Voeg opmerking toe
    5. iPod 1st Generation Logic Board Replacement: stap 5, afbeelding 1 van 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      • Lift the rear panel away from the iPod.
      Vraag FixBot
      Voeg opmerking toe
    1. iPod 1st Generation Logic Board Replacement, Hard Drive: stap 6, afbeelding 1 van 1
      • Lift the battery up from the adhesive holding it to the iPod.
      • Lay the battery next to the iPod (it is still connected to the logic board).
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 1st Generation Logic Board Replacement: stap 7, afbeelding 1 van 1
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      Vraag FixBot
      Voeg opmerking toe
    1. iPod 1st Generation Logic Board Replacement, Display: stap 8, afbeelding 1 van 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 1st Generation Logic Board Replacement: stap 9, afbeelding 1 van 1
      • Peel up the gray rubber bumper near the hard drive ribbon to reveal the T6 Torx screw beneath.
      • Remove the newly revealed T6 Torx screw.
      Vraag FixBot
      Voeg opmerking toe
    3. iPod 1st Generation Logic Board Replacement: stap 10, afbeelding 1 van 1
      • Remove the 3 remaining T6 Torx screws from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. iPod 1st Generation Logic Board Replacement: stap 11, afbeelding 1 van 1
      • Slide the logic board away from the port end of the casing and lift it out of the iPod.
      Vraag FixBot
      Voeg opmerking toe
    5. iPod 1st Generation Logic Board Replacement: stap 12, afbeelding 1 van 1
      • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
      Vraag FixBot
      Voeg opmerking toe
    6. iPod 1st Generation Logic Board Replacement: stap 13, afbeelding 1 van 1
      • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
      Vraag FixBot
      Voeg opmerking toe
    7. iPod 1st Generation Logic Board Replacement: stap 14, afbeelding 1 van 1
      • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
      Vraag FixBot
      Voeg opmerking toe
    1. iPod 1st Generation Logic Board Replacement, Logic Board: stap 15, afbeelding 1 van 1
      • Use a spudger to carefully disconnect the orange hard drive cable from beneath the scroll wheel.
      Vraag FixBot
      Voeg opmerking toe
    2. iPod 1st Generation Logic Board Replacement: stap 16, afbeelding 1 van 1
      • Logic board & attached scroll wheel remain.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
1Gids Commentaar
What if your nipples clicked in and out like pens
Djskfjdhfjjdjsj - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 87
Altijd: 23,289
