Inleiding
prereq only
Wat je nodig hebt
Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
Gereedschap gebruikt in deze stap:Plastic Cards$2.99
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
