Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace the electronic portion of power button and the attached ambient light/proximity sensors.
Wat je nodig hebt
Power off your iPhone before beginning disassembly.
Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Remove the battery.
Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
Remove the thin metal dock connector cable cover.
Remove the following five screws:
Three 1.3 mm Phillips screws
One 1.5 mm Phillips screw
One 2.4 mm Phillips screw
Disconnect the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Power button cable
Front facing camera cable
Digitizer cable
Display data cable
To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
Use the edge of a plastic opening tool to peel the earpiece speaker off the foam adhesive securing it to the iPhone.
Remove the earpiece speaker.
Remove the two 2.0 mm Phillips screws securing the power button bracket to the outer case.
Slightly pull the power button cable bracket away from the outer case.
84 andere personen hebben deze handleiding voltooid.
3 opmerkingen
My power button quit working. I bought the cable assembly and replaced it per these instructions. Everything seemed to work at first but later I noticed my phone kept trying to shut itself off. Any ideas what is causing this? It only seems to occur after I use the power button. It is almost as if it is getting stuck down.
Please remove your screen first, before replacing power button or sensor cable. I advise you to not dare attempt to remove those Step 25 screws (power button cable bracket ) while screen is mounted.
It is too risky! Display's ribbon cable interferes with driver access to these screws. While driving these screws, I unknowingly broke my display cable. It is actually a delicate circuit, not just a simple flexible ribbon. If I knew just how delicate is display cable, then I would not have ventured to perform this replacement. (In my case, only proximity sensor was not working; power and and ambient light sensor were both functioning. In my case, it was not worth breaking a pricy screen for sake of a cheap sensor.)
With a broken screen cable, iPhone endlessly repeats a diagnostic sound or vibration.
iPhone endlessly repeats the "power supply accepted" sound or vibration
