Ga door naar hoofdinhoud
iPhone 3GS Front Panel Assembly Replacement
Wat je nodig hebt
Video overzicht
    1. iPhone 3GS Front Panel Assembly Replacement, Broken Glass: stap 1, afbeelding 1 van 3 iPhone 3GS Front Panel Assembly Replacement, Broken Glass: stap 1, afbeelding 2 van 3 iPhone 3GS Front Panel Assembly Replacement, Broken Glass: stap 1, afbeelding 3 van 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 3GS Front Panel Assembly Replacement, Display: stap 2, afbeelding 1 van 1
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      • Make sure to keep all the screws organized as you are taking the phone apart. They are different sizes.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 3GS Front Panel Assembly Replacement: stap 3, afbeelding 1 van 1
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Use a small suction cup near the Home button to gently pull up the lower portion of the iPhone's display assembly.
      • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 3GS Front Panel Assembly Replacement: stap 4, afbeelding 1 van 1
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 3GS Front Panel Assembly Replacement: stap 5, afbeelding 1 van 1
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      • Ribbon cable "1" is connected with a plug style connector. The block at the end of the cable is the plug which is simply pushed into a socket on the circuit board. No other locking mechanism is used.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 3GS Front Panel Assembly Replacement: stap 6, afbeelding 1 van 1
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 3GS Front Panel Assembly Replacement: stap 7, afbeelding 1 van 2 iPhone 3GS Front Panel Assembly Replacement: stap 7, afbeelding 2 van 2
      • Ribbon cable "3" is held in place by a FPC style connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism.
      • The FPC locking latch is very delicate and is typically a different color than the body of the connector. (see the detail image of FPC connector open and closed)
      • Slide the ribbon cable out of the connector, and remove the display assembly from the iPhone.
      • It's impossible to properly reinsert a ribbon into an FPC connector unless the lock is disengaged. Make sure the locking latch is open when attaching/detaching the cable.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 3GS Front Panel Assembly Replacement: stap 8, afbeelding 1 van 1
      • Remove the single Phillips #00 screw from the corner of the display assembly.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 3GS Front Panel Assembly Replacement: stap 9, afbeelding 1 van 1
      • Remove the two Phillips #00 screws from the right side of the display assembly.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 3GS Front Panel Assembly Replacement: stap 10, afbeelding 1 van 1
      • Turn the display around, and if there is a thin strip of black tape on the edge of the display assembly, carefully peel it up.
      • Keeping the tape from sticking to itself can be tricky. We recommend placing the tape on a wax-coated piece of paper (any sticker backing will do).
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 3GS Front Panel Assembly Replacement: stap 11, afbeelding 1 van 1
      • Remove the three Phillips #00 screws from the left side of the display assembly.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 3GS Front Panel Assembly Replacement: stap 12, afbeelding 1 van 1
      • Turn the display assembly over and again carefully insert a metal spudger between the two metal rails along the edge of the display assembly. Gently rotate the spudger to lift the LCD up from the glass.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 3GS Front Panel Assembly Replacement: stap 13, afbeelding 1 van 1
      • Separate the LCD and glass by sliding the LCD panel away from the ribbon cables on the glass.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 3GS Front Panel Assembly Replacement, Front Panel Assembly: stap 14, afbeelding 1 van 1
      • Front Panel Assembly remains.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
333 andere personen hebben deze handleiding voltooid.
9Gids Commentaar
do not forget to remove the smart cart!!
if less than an hour to remove and replace the new front panel.
sylval1 - Antwoord Deel
tf? what is the smart cart?
Crystal Haugh - Antwoord Deel
The hardest parts are separating the glass from the plastics and then re-attaching it. It would do you well to buy the 'custom' double sided sticky tape they sell here at ifixit. I used regular double sided tape and it took a long time to cut and fit properly so all sensors would remain working and the screen would be held in place.
damuta - Antwoord Deel
If your screen is severely damaged, there is no way to separate the digitizer from the outside glass without destroying the digitizer, is there? I couldn't do it. Also, nail polish remover is good for getting rid of the adhesive!
Michael - Antwoord Deel
Be careful putting the new screen back in. I got almost all the way to done and everything was working perfectly - then I had trouble getting the bottom portion of the assembly (near the home button) back in.
I forced it a bit thinking I had squeeze it in and cracked the new screen. Doh.
Mxfive4 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 63
Altijd: 252,793
