Ga door naar hoofdinhoud
iPhone 3GS Display Assembly Replacement
Wat je nodig hebt
Video overzicht
    1. iPhone 3GS Display Assembly Replacement, Broken Glass: stap 1, afbeelding 1 van 3 iPhone 3GS Display Assembly Replacement, Broken Glass: stap 1, afbeelding 2 van 3 iPhone 3GS Display Assembly Replacement, Broken Glass: stap 1, afbeelding 3 van 3
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 3GS Display Assembly Replacement, Display Assembly: stap 2, afbeelding 1 van 1
      • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 3GS Display Assembly Replacement: stap 3, afbeelding 1 van 1
      • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
      • Be very careful when opening the iPhone so that the cables under the display are not severed.
      • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
      • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
      • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 3GS Display Assembly Replacement: stap 4, afbeelding 1 van 1
      • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
      • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 3GS Display Assembly Replacement: stap 5, afbeelding 1 van 1
      • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 3GS Display Assembly Replacement: stap 6, afbeelding 1 van 1
      • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
      • Use a spudger to disconnect the black ribbon cable labeled "2."
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 3GS Display Assembly Replacement: stap 7, afbeelding 1 van 1
      • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
      • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
      • The plastic tab may be white (instead of black) on some iPhone models.
      • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
407 andere personen hebben deze handleiding voltooid.
9Gids Commentaar
I had no issues taking the 3GS apart;however, putting the new screen assembly back together was a little more difficult. I can't get the new screen to 'stay flush' with the bezel. Also the 'gasket'(that runs around the length of the new assembly) keeps getting pinched and doesn't 'snap' under the bezel properly. I'm going through other procedures to see how to remedy this.
damuta - Antwoord Deel
I did everything very simple to do for a Rookie, but the only issue I had was the screen wasn't calibrate I will type number and another number will show. I check the cables several time but no luck...anyone feel free to response...
barbara2333 - Antwoord Deel
Replaced the dock with success, now my phone starts and does everything it should however I can't get any signal from my carrier, anybody have any suggestions other than buying a new phone!
James - Antwoord Deel
Simple job. I made the mistake of ordering the assembly with the glass and the button and speaker in one. I'm glad I did. I have done the glass only repair, and it's a far more difficult job, to carve away the shattered shards on gorilla glass. My advice: spend a liitle extra, get the assembly with the electronics in tact, and just deal with attaching the LCD and the ribbon connections.
bearleton - Antwoord Deel
I just received my order today and I was able to follow all of the steps with ease. And I was able to repair my iPhone 3GS in about 25 minutes. All I have to do now is charge the new battery and everything is good to go. Great guide and very easy to follow.
jtking007 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 79
Altijd: 302,263
