Ga door naar hoofdinhoud
iPhone 3G Display Assembly Replacement
Wat je nodig hebt
Video overzicht
  1. iPhone 3G Display Assembly Replacement, Broken Glass: stap 1, afbeelding 1 van 3 iPhone 3G Display Assembly Replacement, Broken Glass: stap 1, afbeelding 2 van 3 iPhone 3G Display Assembly Replacement, Broken Glass: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Vraag FixBot
    Voeg opmerking toe
  2. iPhone 3G Display Assembly Replacement, Display Assembly: stap 2, afbeelding 1 van 1
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  3. iPhone 3G Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
    Vraag FixBot
    Voeg opmerking toe
  4. iPhone 3G Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    Vraag FixBot
    Voeg opmerking toe
  5. iPhone 3G Display Assembly Replacement: stap 5, afbeelding 1 van 1
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    Vraag FixBot
    Voeg opmerking toe
  6. iPhone 3G Display Assembly Replacement: stap 6, afbeelding 1 van 1
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    Vraag FixBot
    Voeg opmerking toe
  7. iPhone 3G Display Assembly Replacement: stap 7, afbeelding 1 van 1
    • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
    • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
    • The plastic tab may be white (instead of black) on some iPhone models.
    • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
229 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
i went through the whole process, but my home button does not work anymore. it was fine when I started - its it possible, that one ribbon is not fully attached ore is there any other solution? Thanks for any advice!
Jakob
JakobBartke - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 89
Altijd: 305,314
