Inleiding
If you've tried cleaning the lightning port to no avail, use this guide to replace the Lightning connector assembly in your iPhone 11, which can resolve many charging and connectivity issues.
Wat je nodig hebt
Video-instructies
41 andere personen hebben deze handleiding voltooid.
14 opmerkingen
I would rather have a picture and written step by step, he doesn’t say some parts what is called
Dulce Vidal - Antwoord
Me too. I would appreciate knowing the size and type of all screws and standoffs and where they go.
I most likely mixed up a few of them and now the screen stays black.
Kim Mace -
First, DISCONNECT the battery before ANY connections, and the battery should be the last thing you re-connect. And you DO NOT need to remove the logic board.
Gregg Stanley - Antwoord
Just completed this repair. Wow it’s tricky but as echoed above, I would try and disconnect battery first although design of the iPhone 11 makes it very difficult to do this. Also, definitely don’t remove logic board and you don’t have to remove the battery either. Removing battery possibly makes it very slightly easier but if you take your time it’s not necessary. Good luck
richarddillon - Antwoord
IS not there a problem with at chip on the charging flex, that causes warnings and or re-boots I have been reading about somewhere?I mean, fitting it is easy enough, but APPPPle keeps annoying customers trying to stop them going to independent shops or doing repairs themselves!
JoeBlog - Antwoord
