Inleiding
Follow this guide to remove the iPad's logic board.
Onderdelen
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Insert a metal spudger between the top edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
With one spudger, work your way along the right edge of the iPad.
The front panel is held to the aluminum back by metal clips on the top, bottom, and left sides. The right side has plastic tabs which slide into recesses in the backplate.
Once the clips are released, lift the left side of the front panel up and slide it to the left to clear the tabs from the aluminum backplate.
Use the edge of a plastic opening tool to:
Pry the side button connector up off the logic board from underneath the wires.
Pry the speaker connector up off its socket on the logic board from beneath the speaker wires.
Carefully flip up the ZIF ribbon cable retaining flap on the socket near the headphone jack.
Pull the headphone jack ribbon cable toward the left side of the iPad to disconnect it from its socket.
26 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
Isn't the firmware containing the serial number on the logic board? If so you would need to add the serial number back in right?
Can I change the logic board from another iPad to this one?
Hi my gen 5 ipod touch( yep had it forever) screen broke yet that far back replacing that not worth the effort. Want to try and use any hardware it didn't ruin when i sat on it. try to connect to my hp monitor from 2003? Maybe? thanks for reading. cheers
