Ga door naar hoofdinhoud
iPad Mini Home button Replacement
Wat je nodig hebt
    1. iPad Mini Home button Replacement, Reveal solder pads: stap 1, afbeelding 1 van 1
      • Use heat to losen the adhesive. A low temp hot air gun will suffice.
      • After heating up the adhesive, you can use a basic spudger to pry off the flex from the glass
      • be sure not to use too much force, this flex is very fragile.
      Vraag FixBot
      Voeg opmerking toe
    2. iPad Mini Home button Replacement, Apply your own solder: stap 2, afbeelding 1 van 1
      • use your iron, and low guage solder to apply a layer of your own solder on the pads
      • the new solder will allow for faster, and more controlled heat transfer.
      Vraag FixBot
      Voeg opmerking toe
    3. iPad Mini Home button Replacement, Remove the flex: stap 3, afbeelding 1 van 1
      • a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
      • be sure not to apply too much force with the iron, as you can cause physical damage to the pads.
      • Using a little bit of solder flux, can help decrease the amount of pressure needed to properly transfer the heat.
      Vraag FixBot
      Voeg opmerking toe
    4. iPad Mini Home button Replacement, Line up the pads: stap 4, afbeelding 1 van 1
      • be sure to make sure you can see directly through the holes marked on both sides.
      • Line the corrisponding holes up, and make sure they are 100% overlapped.
      • failing to properly line up the holes can cause a short, or cold circuit.
      Vraag FixBot
      Voeg opmerking toe
    5. iPad Mini Home button Replacement, Re-Solder: stap 5, afbeelding 1 van 1
      • Use the new solder you added, to connect to the flex.
      • be sure to cover the traces with some electrical tape to avoid shorts.
      • congratulations on your home button replacement
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Scott
9.973 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 85
Altijd: 13,227
