Ga door naar hoofdinhoud
iPad Mini 6 Volume Buttons Replacement
Wat je nodig hebt
  1. iPad Mini 6 Volume Buttons Replacement, Apply tape to a cracked screen: stap 1, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Apply tape to a cracked screen: stap 1, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Apply tape to a cracked screen: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. Voorzichtig: stappen 2-13 komen van een handleiding die in bewerking is.
    iPad Mini 6 Volume Buttons Replacement, Heat the bottom edge: stap 2, afbeelding 1 van 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Volume Buttons Replacement, Screen removal information: stap 3, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Screen removal information: stap 3, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Screen removal information: stap 3, afbeelding 3 van 3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Volume Buttons Replacement, Insert an opening pick: stap 4, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Insert an opening pick: stap 4, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Insert an opening pick: stap 4, afbeelding 3 van 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Volume Buttons Replacement, Separate the bottom adhesive: stap 5, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom adhesive: stap 5, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom adhesive: stap 5, afbeelding 3 van 3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Volume Buttons Replacement, Heat the right edge: stap 6, afbeelding 1 van 1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Volume Buttons Replacement, Separate the bottom-right corner adhesive: stap 7, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom-right corner adhesive: stap 7, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Separate the bottom-right corner adhesive: stap 7, afbeelding 3 van 3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Volume Buttons Replacement, Separate the remaining adhesive: stap 8, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Separate the remaining adhesive: stap 8, afbeelding 2 van 2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Volume Buttons Replacement, Reposition the screen: stap 9, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Reposition the screen: stap 9, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Reposition the screen: stap 9, afbeelding 3 van 3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Volume Buttons Replacement, Unfasten the display cable bracket: stap 10, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Unfasten the display cable bracket: stap 10, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Volume Buttons Replacement, Remove the display cable bracket: stap 11, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Remove the display cable bracket: stap 11, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Volume Buttons Replacement, Disconnect the display: stap 12, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Disconnect the display: stap 12, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Disconnect the display: stap 12, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Volume Buttons Replacement, Remove the screen: stap 13, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Remove the screen: stap 13, afbeelding 2 van 2
    • Remove the screen from the frame.
  14. iPad Mini 6 Volume Buttons Replacement, Disconnect the battery: stap 14, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Disconnect the battery: stap 14, afbeelding 2 van 2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Mini 6 Volume Buttons Replacement, Unfasten the front camera shield: stap 15, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Unfasten the front camera shield: stap 15, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
  16. iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: stap 16, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: stap 16, afbeelding 2 van 2
    • Use the tip of a spudger to pry up and disconnect the volume button board's coaxial cable.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  17. iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board's coaxial cable: stap 17, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board's coaxial cable: stap 17, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the 1 mm screw securing the volume button board's coaxial cable to the frame.
  18. iPad Mini 6 Volume Buttons Replacement, Reposition the coaxial cable: stap 18, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Reposition the coaxial cable: stap 18, afbeelding 2 van 2
    • Use tweezers, or your fingers, to pull the coaxial cable away from the frame, making sure to separate the tape keeping it in place.
  19. iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: stap 19, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Disconnect the volume button board: stap 19, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
  20. iPad Mini 6 Volume Buttons Replacement, Reposition the volume button board's cable: stap 20, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Reposition the volume button board's cable: stap 20, afbeelding 2 van 2
    • Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
  21. iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board: stap 21, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Unfasten the volume button board: stap 21, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the eleven screws securing the volume button board to the frame:
    • One 2.1 mm screw
    • Six 1.4 mm screws
    • Two 2.2 screws
    • Two 1.2 mm screws
  22. iPad Mini 6 Volume Buttons Replacement, Separate the volume button bracket: stap 22, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Separate the volume button bracket: stap 22, afbeelding 2 van 2
    • Use an opening pick, or a spudger, to pry the volume button bracket out of its plastic clips.
  23. iPad Mini 6 Volume Buttons Replacement, Separate the volume button board's adhesive: stap 23, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Separate the volume button board's adhesive: stap 23, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Separate the volume button board's adhesive: stap 23, afbeelding 3 van 3
    • The volume button board is lightly adhered to the frame.
    • Insert an opening pick between the volume button board and the frame.
    • Slice while prying up with the pick to separate the adhesive.
  24. iPad Mini 6 Volume Buttons Replacement: stap 24, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement: stap 24, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement: stap 24, afbeelding 3 van 3
    • Gently peel the volume button board away from the frame to completely separate the adhesive.
  25. iPad Mini 6 Volume Buttons Replacement, Remove the volume button board: stap 25, afbeelding 1 van 2 iPad Mini 6 Volume Buttons Replacement, Remove the volume button board: stap 25, afbeelding 2 van 2
    • Use your fingers to remove the volume button board.
  26. iPad Mini 6 Volume Buttons Replacement, Remove the volume buttons: stap 26, afbeelding 1 van 3 iPad Mini 6 Volume Buttons Replacement, Remove the volume buttons: stap 26, afbeelding 2 van 3 iPad Mini 6 Volume Buttons Replacement, Remove the volume buttons: stap 26, afbeelding 3 van 3
    • Use tweezers, or your fingers, to remove the volume buttons from their slots in the frame.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Alex Diaz-Kokaisl
163.249 Reputatie
769 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.537 handleidingen geschreven
Één opmerking
It's nice that you have instructions, but where do I find the parts? My volume up button stopped working after it got a little wet. Is that a tell for Apple that it had moisture exposure?
RobCow - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 82
Altijd: 2,769
