Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je iPad ClamCase te repareren, gebruik onze reparatiehandleidingen.
  1. iPad ClamCase, iPad ClamCase: stap 1, afbeelding 1 van 2 iPad ClamCase, iPad ClamCase: stap 1, afbeelding 2 van 2
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
    Vraag FixBot
    Voeg opmerking toe
  2. iPad ClamCase: stap 2, afbeelding 1 van 2 iPad ClamCase: stap 2, afbeelding 2 van 2
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
    Vraag FixBot
    Voeg opmerking toe
  3. iPad ClamCase: stap 3, afbeelding 1 van 2 iPad ClamCase: stap 3, afbeelding 2 van 2
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
    Vraag FixBot
    Voeg opmerking toe
  4. iPad ClamCase: stap 4, afbeelding 1 van 1
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
    Vraag FixBot
    Voeg opmerking toe
  5. iPad ClamCase: stap 5, afbeelding 1 van 1
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
    Vraag FixBot
    Voeg opmerking toe
  6. iPad ClamCase: stap 6, afbeelding 1 van 1
    • You are done.
    Vraag FixBot
    Voeg opmerking toe
Izmet Barranco
213 Reputatie
1 Handleiding geschreven
2Gids Commentaar
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Antwoord Deel
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 8,224
