Inleiding
Use this guide to replace the LCD display.
Gereedschap
Onderdelen
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
28 andere personen hebben deze handleiding voltooid.
6 Opmerkingen
I damaged the lcd frame (with magnets) and I don't know where to find it. Can you guys help?
It's just the frame with magnets that attaches the lcd screen...
hey thanks for this.... i had to swap LCDs due to well known streak/screen fault.
after over 2 years using external display for work, i saw this blog and thought i might try.
the stakes were extremely high (my wife's iMac and no cash to get OOW apple repair, but your help got me through it. super cheers.
NB. i found this other thread most helpful re: the side strips that screw to the LCD panel and the iMac chassis.
I'd like to buy IMAC LCD Model: ME086ZP/A. Where can I buy this item?
Hi, is that possible to replace the LCD diaplay by a 4k display?
