Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the following three screws securing the inverter to the chassis:
Two 7.9 mm Phillips.
One 26 mm Phillips.
Slide the inverter toward the edge of the mid-plane, then lift it out of the iMac.
Disconnect the large inverter cable connector from the inverter by pulling straight away from its socket.
Disconnect the small inverter cable connector by pulling it straight away from its socket.
Disconnect the hard drive thermal sensor cable from the thermal sensor board on the hard drive bracket by pulling the cable away from the heat sink.
Gently pull the black inverter cable to disconnect it from the logic board.
Flip up the inverter cable cover from its left edge and lift it out of the chassis.
De-route the inverter cables from the inverter cable cover hook.
Remove the inverter cables from the inverter cable cover, and disconnect both connectors.
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Pull the optical drive up by its white pull tab to disconnect it from the logic board.
Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
Lift the optical drive out of your iMac.
Remove the two 7.3 mm shouldered Phillips screws securing the display cable connector to the logic board.
Pull the display data cable up off the logic board by its black pull tab.
De-route the display cable from the two aluminum fingers in the mid-plane.
Loosen the center Phillips screw securing the power supply to the front case.
Remove the four coarse-thread 7.8 mm Phillips screws along the top edge of the iMac.
Remove the following two screws:
One 7 mm Phillips.
One 26 mm Phillips.
Remove the six 7.2 mm coarse-thread T10 Torx screws securing the display to the front case.
18 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Excellent Thank you
Very detailed. Thank you.
