Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement
Wat je nodig hebt
  1. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate: stap 1, afbeelding 1 van 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: stap 2, afbeelding 1 van 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the base access panel.
  4. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate Housing: stap 4, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement, Bottom Plate Housing: stap 4, afbeelding 2 van 2
    • Remove the four 25mm T-15 screws.
  5. iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: stap 5, afbeelding 1 van 2 iMac G4 17 800 MHz EMC 1936 Bottom Plate Housing Replacement: stap 5, afbeelding 2 van 2
    • Open the housing plate.
    • Be gentle with the wires still connected to the logic board so as not to ruin the cables.
    • A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Justin
303 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-22, Maness Fall 2011 Lid van Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Leden
13 handleidingen geschreven
Één opmerking
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
amicuset - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 2,169
