Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Open the housing plate.
A fixed plug connector between the logic board and upper unit will cause some resistance. Pull gently but firmly.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
If you do this - don't you still need to apply a fresh coat of thermal paste to the exposed ends of the two heat-sink posts (that separate when you open a G4 flatpanel this far) - my understanding was that the machine would overheat and you'd be left with didley squat!!
Gregg :O)
