Inleiding
Use this guide to remove, replace, or upgrade the RAM in your iMac Intel 27" Retina 5K Display.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Wat je nodig hebt
While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
Re-insert the RAM access door back into its place.
6 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
bom dia, posso trocar a memoria de 2444MHZ para 2666MHZ? 3000MHZ ?
