Ga door naar hoofdinhoud
iHome iPL8 Lightning Connector Replacement
Wat je nodig hebt
    1. iHome iPL8 Lightning Connector Replacement, Battery: stap 1, afbeelding 1 van 1
      • Turn the device over to access the bottom panel.
      • Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iPL8 Lightning Connector Replacement: stap 2, afbeelding 1 van 1
      • Using a Phillips #2 screwdriver, unscrew the captive screw.
      • Keep turning until the screw and the door are loose.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome iPL8 Lightning Connector Replacement: stap 3, afbeelding 1 van 1
      • Lift and remove the battery access panel.
      • The captive screw will remain attached to the panel.
      Vraag FixBot
      Voeg opmerking toe
    4. iHome iPL8 Lightning Connector Replacement: stap 4, afbeelding 1 van 2 iHome iPL8 Lightning Connector Replacement: stap 4, afbeelding 2 van 2
      • Gently press on the rim of the 3V battery.
      • Remove the 3V battery.
      Vraag FixBot
      Voeg opmerking toe
    1. iHome iPL8 Lightning Connector Replacement, Lightning Connector: stap 5, afbeelding 1 van 1
      • Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
      • Remove the four 6mm Phillips #2 screws.
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iPL8 Lightning Connector Replacement: stap 6, afbeelding 1 van 1
      • Remove the four round pads from the bottom of the device.
      • There are two additional 6mm Phillips #2 screws under the pads.
      • Using a Phillips #2 screwdriver, remove the two remaining screws.
      • Put your hand on the silver bottom case and gently pull it outward.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome iPL8 Lightning Connector Replacement: stap 7, afbeelding 1 van 2 iHome iPL8 Lightning Connector Replacement: stap 7, afbeelding 2 van 2
      • Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
      • Pull out the green circuit board on the two corners.
      • The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
      Vraag FixBot
      Voeg opmerking toe
    4. iHome iPL8 Lightning Connector Replacement: stap 8, afbeelding 1 van 2 iHome iPL8 Lightning Connector Replacement: stap 8, afbeelding 2 van 2
      • Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
      • Remove the two screws and the black cover.
      • Gently remove the lightning dock assembly.
      • The lightning dock assembly is connected to wires.
      Vraag FixBot
      Voeg opmerking toe
    5. iHome iPL8 Lightning Connector Replacement: stap 9, afbeelding 1 van 3 iHome iPL8 Lightning Connector Replacement: stap 9, afbeelding 2 van 3 iHome iPL8 Lightning Connector Replacement: stap 9, afbeelding 3 van 3
      • Remove the two 2.5mm screws using a Phillips #1 screwdriver.
      • Remove the back cover.
      • Use your fingers to reposition the lightning connector.
      • Make sure ALL of the lightning connector is exposed.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Chen Zhong
569 Reputatie
4 handleidingen geschreven
UC Davis, Team S18-G5, Lore Winter 2019 Lid van UC Davis, Team S18-G5, Lore Winter 2019
UCD-LORE-W19S18G5
3 Leden
8 handleidingen geschreven
3Gids Commentaar
where can I find the replacement lightning connector?
Bond 007 and a Half - Antwoord Deel
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
Shawn Simmons - Antwoord Deel
I’m trying to find the replacement part to buy too.
Wendy - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 964
