Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Orient the iHome upside down with the speakers facing away from you.
Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
Remove the back cover by grabbing its sides and lifting it off the iHome.
Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
3 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Were you able to buy the motherboard?
Rodrigo -
