Ga door naar hoofdinhoud
iHome iH9 Antenna Replacement
Wat je nodig hebt
  1. iHome iH9 Antenna Replacement, Backup Batteries: stap 1, afbeelding 1 van 3 iHome iH9 Antenna Replacement, Backup Batteries: stap 1, afbeelding 2 van 3 iHome iH9 Antenna Replacement, Backup Batteries: stap 1, afbeelding 3 van 3
    • Pull the tab towards you and lift up to remove the battery cover.
    • Remove the two AA batteries.
  2. iHome iH9 Antenna Replacement, Opening the iHome iH9: stap 2, afbeelding 1 van 1
    • Unscrew the four 8mm Phillips #2 screws.
    • Unscrew the six 25mm Phillips #2 screws.
    • Reinstall the backup battery cover so it is out of the way.
  3. iHome iH9 Antenna Replacement: stap 3, afbeelding 1 van 3 iHome iH9 Antenna Replacement: stap 3, afbeelding 2 van 3 iHome iH9 Antenna Replacement: stap 3, afbeelding 3 van 3
    • Pry the backplate up with a plastic opening tool between the back plate and the speaker grill.
    • Be careful when lifting the bottom plate up; there is a short white and orange 4-pin connector attached to its underside.
    • Lift the bottom plate up while making sure the connector remains attached.
  4. iHome iH9 Antenna Replacement: stap 4, afbeelding 1 van 3 iHome iH9 Antenna Replacement: stap 4, afbeelding 2 van 3 iHome iH9 Antenna Replacement: stap 4, afbeelding 3 van 3
    • Use your hands to flip the backing plate away from you and rest it upside down on the iH9.
    • Unplug the white and orange 4-pin connector by pulling it in the direction of the wires.
    • Set the backing plate aside.
  5. iHome iH9 Antenna Replacement: stap 5, afbeelding 1 van 1
    • Place the device so that the speaker grill is face down.
    • Remove the two 10mm Phillips #2 screws on interior sides of the speaker housings.
  6. iHome iH9 Antenna Replacement: stap 6, afbeelding 1 van 2 iHome iH9 Antenna Replacement: stap 6, afbeelding 2 van 2
    • Place the iH9 upside down.
    • Wires connect the core assembly to the housing; do not attempt to pull the core assembly completely out.
    • Using both hands, pull the housing siding away from the device while simultaneously lifting the motherboard and speaker assembly straight up.
    • Repeat for the other side.
  7. iHome iH9 Antenna Replacement: stap 7, afbeelding 1 van 1
    • Stand the iH9 on its grill.
    • Separate the motherboard and speaker assembly by rocking it back and forth and pulling the assembly towards you.
    • Remove the small back panel.
  8. iHome iH9 Antenna Replacement: stap 8, afbeelding 1 van 3 iHome iH9 Antenna Replacement: stap 8, afbeelding 2 van 3 iHome iH9 Antenna Replacement: stap 8, afbeelding 3 van 3
    • Firmly pull the wide 9-pin connector with black covering on the underside of the upper housing to unplug it.
    • Lay the housing and core assembly flat and close to each one another.
  9. iHome iH9 Antenna Replacement: stap 9, afbeelding 1 van 2 iHome iH9 Antenna Replacement: stap 9, afbeelding 2 van 2
    • Unplug the narrow 9-pin connector from the motherboard.
  10. iHome iH9 Antenna Replacement: stap 10, afbeelding 1 van 1
    • Cut the zip tie holding the wires together with a wire cutter. The two sides of the device housing are now fully separated.
  11. iHome iH9 Antenna Replacement, Antenna: stap 11, afbeelding 1 van 2 iHome iH9 Antenna Replacement, Antenna: stap 11, afbeelding 2 van 2
    • Set the motherboard assembly upside down to expose the spot of glue holding the antenna to the motherboard.
    • Pry up the glue with a metal spuger.
  12. iHome iH9 Antenna Replacement: stap 12, afbeelding 1 van 3 iHome iH9 Antenna Replacement: stap 12, afbeelding 2 van 3 iHome iH9 Antenna Replacement: stap 12, afbeelding 3 van 3
    • Flip the assembly over, the solder point is on the side opposite where the antenna comes out
    • Heat this point with a soldering iron while gently pulling the antenna down.
    • See the "How to Solder and Desolder Connections" guide
Conclusie
Charlie Ross
345 Reputatie
3 handleidingen geschreven
Cal Poly, Team 8-39, Amido Winter 2015 Lid van Cal Poly, Team 8-39, Amido Winter 2015
CPSU-AMIDO-W15S8G39
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 2,075
