Ga door naar hoofdinhoud
iHome iH27B Left Control Button Replacement
Wat je nodig hebt
    1. iHome iH27B Left Control Button Replacement, Outer Case: stap 1, afbeelding 1 van 1
      • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
      • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iH27B Left Control Button Replacement: stap 2, afbeelding 1 van 3 iHome iH27B Left Control Button Replacement: stap 2, afbeelding 2 van 3 iHome iH27B Left Control Button Replacement: stap 2, afbeelding 3 van 3
      • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
      • Remove the plastic slide from its location and set it aside.
      • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
      • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
      • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
      • Set the plastic covering and the watch battery aside.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome iH27B Left Control Button Replacement: stap 3, afbeelding 1 van 1
      • Remove the following screws:
      • Eight 10 mm using the Phillips #0 on the bottom of your device.
      • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
      Vraag FixBot
      Voeg opmerking toe
    4. iHome iH27B Left Control Button Replacement: stap 4, afbeelding 1 van 1
      • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
      • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
      Vraag FixBot
      Voeg opmerking toe
    5. iHome iH27B Left Control Button Replacement: stap 5, afbeelding 1 van 1
      • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
      • You should have visible access to most of the components inside the iHome now.
      Vraag FixBot
      Voeg opmerking toe
    1. iHome iH27B Left Control Button Replacement, AV circuit board: stap 6, afbeelding 1 van 1
      • Two 10 mm Phillips #0
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iH27B Left Control Button Replacement: stap 7, afbeelding 1 van 1
      • Pull out the AV circuit board and lift it up and out of the way to allow access to other components.
      Vraag FixBot
      Voeg opmerking toe
    1. iHome iH27B Left Control Button Replacement, Main Motherboard: stap 8, afbeelding 1 van 1
      • Pull the speakers away and set them aside for now. They should still be connected to the rest of the iHome by two wires.
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iH27B Left Control Button Replacement: stap 9, afbeelding 1 van 1
      • Remove the following 6 screws:
      • Two 7 mm Phillips #0
      • Three 10 mm Phillips #2
      • One 9 mm Phillips #2
      • Set the screws aside, careful to not mix them up with your other screws.
      Vraag FixBot
      Voeg opmerking toe
    1. iHome iH27B Left Control Button Replacement, Left Control Button: stap 10, afbeelding 1 van 2 iHome iH27B Left Control Button Replacement, Left Control Button: stap 10, afbeelding 2 van 2
      • Remember that the device is still upside down, so the left control button will be on your right hand side. Then rotate the device 180 degrees. You should see the device as it looks in the picture.
      • Carefully lift the iHome about an inch from your surface to verify you are going to the correct spot, because the iHome looks symmetrical at this point.
      • Carefully lift the main motherboard out of the way of the button control circuit board.
      • Four 6 mm Phillips #2
      Vraag FixBot
      Voeg opmerking toe
    2. iHome iH27B Left Control Button Replacement: stap 11, afbeelding 1 van 2 iHome iH27B Left Control Button Replacement: stap 11, afbeelding 2 van 2
      • Carefully lift the button control motherboard out of the way.
      • Place your fingers on each of the four notches. Apply pressure towards the center, and push downwards until the plastic piece is dislodged from its casing.
      • If your fingers aren't working, use a flathead screwdriver or plastic prying tool to give you extra leverage.
      Vraag FixBot
      Voeg opmerking toe
    3. iHome iH27B Left Control Button Replacement: stap 12, afbeelding 1 van 1
      • Replace your cracked or otherwise broken button with the new button.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
John Kraemer
76 Reputatie
9 handleidingen geschreven
Cal Poly, Team 3-21, Amido Fall 2012 Lid van Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Leden
27 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 28
Altijd: 1,234
