Ga door naar hoofdinhoud
iHome iBT16 Motherboard Replacement
Wat je nodig hebt
  1. iHome iBT16 Motherboard Replacement, Base Plate: stap 1, afbeelding 1 van 2 iHome iBT16 Motherboard Replacement, Base Plate: stap 1, afbeelding 2 van 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
  2. iHome iBT16 Motherboard Replacement: stap 2, afbeelding 1 van 2 iHome iBT16 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
  3. iHome iBT16 Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 3 iHome iBT16 Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 3 iHome iBT16 Motherboard Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Connect the ground strap to earth ground and put it around your wrist.
    • Unscrew the two 10mm silver phillips screws holding the motherboard in place on the inside of the device.
    • Use the plastic opening tool to pry the motherboard out of the device housing.
  4. iHome iBT16 Motherboard Replacement: stap 4, afbeelding 1 van 2 iHome iBT16 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • If you are unfamiliar with soldering and unsoldering components, see the Soldering Skills Guide.
    • Unsolder the red and black wires connecting the speaker to the motherboard.
    • Flip the motherboard over.
    • Unsolder the red and black wires connecting the battery to the motherboard.
    • When reassembling your device, be sure to connect the speaker and battery with correct polarity.
  5. iHome iBT16 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the plastic cover from the power switch actuator on the motherboard.
Conclusie
Joseph Hazel
329 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,129
