Ga door naar hoofdinhoud
Inleiding
This guide will show how to install a new mother board in the iHome. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. Remove the two Phillips #1 9.0mm screws on the back of the iHome. Repeat the previous step for the two 9.0mm screws on the bottom.
    • Remove the two Phillips #1 9.0mm screws on the back of the iHome.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
  3. Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Remove the aluminum bracket by loosening the two nuts and removing the 8.0 mm bolts.
    • Pull the bracket out.
  4. Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver. Slide the motherboard gently out.
    • Remove the two 12.0mm screws that hold the motherboard with a Phillips #1 screwdriver.
    • Slide the motherboard gently out.
  5. Solder each wire to corresponding input on the motherboard.
    • Solder each wire to corresponding input on the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Courtney Steinberg
35 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-9, Maness Spring 2013 Lid van Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 324
