Ga door naar hoofdinhoud
iFit Act Battery Replacement
Wat je nodig hebt
  1. iFit Act Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Hold the iFit band in both hands, with your thumbs on either side of the tracker pod at the center of the wristband.
  2. iFit Act Battery Replacement: stap 2, afbeelding 1 van 1
    • Using your index finger, gently push the tracker pod out of the wristband. It may help to do this over a table or other surface so the tracker pod doesn’t fall on the floor and break.
  3. iFit Act Battery Replacement: stap 3, afbeelding 1 van 1
    • Once the tracker pod is freed from the wristband, remove the back of the tracker pod using the plastic opening tool. The tool’s curved edge should be pointed toward the back of the device to avoid scratching the front display.
  4. iFit Act Battery Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the curved metal precision tweezers, gently lift the battery out of the tracker pod.
  5. iFit Act Battery Replacement: stap 5, afbeelding 1 van 1
    • Place the new battery in the tracker pod. Make sure the positive side of the battery is face down in the cavity of the tracker pod.
  6. iFit Act Battery Replacement: stap 6, afbeelding 1 van 1
    • To close the tracker pod, place the top and bottom pieces between fingers as shown and snap them together.
Conclusie
To assemble this device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Charlotte Asmuth
104 Reputatie
1 Handleiding geschreven
2 opmerkingen
The directions state that battery CR2032 is the battery for the ifit.act. I purchased this battery and it does not fit. Where can I get the battery that is compatible with ifit.act?
Revice Fisher - Antwoord
The original battery should have identifying markings on the top so you can purchase an identical replacement. A standard CR 2032 coin cell battery is what’s specified by the manufacturer.
Jeff Suovanen -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 58
Altijd: 15,204
