Ga door naar hoofdinhoud
iBook G3 Clamshell Hard Drive Replacement
Wat je nodig hebt
    1. iBook G3 Clamshell Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Airport Card: stap 2, afbeelding 1 van 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 3, afbeelding 1 van 1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 4, afbeelding 1 van 1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Keyboard: stap 5, afbeelding 1 van 1
      • Remove the two Phillips screws that secure the RAM shield.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 6, afbeelding 1 van 1
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 7, afbeelding 1 van 1
      • Pull up the keyboard connector cable by its clear plastic loop.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Upper Case: stap 8, afbeelding 1 van 1
      • Use a straightened paperclip to manually eject the CD-ROM tray.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 9, afbeelding 1 van 1
      • Turn the computer over so that the bottom is facing up.
      • Remove the following Torx screws:
      • Four short T8 Torx near the battery compartment.
      • Two long T8 Torx near the hinges.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 10, afbeelding 1 van 1
      • Pull the CD-ROM drive tray partly out.
      • Remove the silver Phillips screw from the plastic casing.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell Hard Drive Replacement: stap 11, afbeelding 1 van 1
      • Turn the computer over.
      • Remove the three Phillips screws.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 Clamshell Hard Drive Replacement: stap 12, afbeelding 1 van 1
      • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Vraag FixBot
      Voeg opmerking toe
    6. iBook G3 Clamshell Hard Drive Replacement: stap 13, afbeelding 1 van 1
      • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
      • Slide the orange trackpad ribbon out of the clamp.
      Vraag FixBot
      Voeg opmerking toe
    7. iBook G3 Clamshell Hard Drive Replacement: stap 14, afbeelding 1 van 1
      • Do not lift the upper case too far without first disconnecting the audio cable.
      • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
      • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
      Vraag FixBot
      Voeg opmerking toe
    8. iBook G3 Clamshell Hard Drive Replacement: stap 15, afbeelding 1 van 1
      • Disconnect the audio cable.
      Vraag FixBot
      Voeg opmerking toe
    9. iBook G3 Clamshell Hard Drive Replacement: stap 16, afbeelding 1 van 1
      • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
      • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Optical Drive: stap 17, afbeelding 1 van 1
      • If the optical drive is not open, use a straightened paperclip to open it now.
      • Remove the 5 mm standoff.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 18, afbeelding 1 van 1
      • Disconnect the optical drive cable from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 19, afbeelding 1 van 1
      • Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
      • Lift up the side of the optical drive you just freed and slide the drive out and away from the screen.
      • When reinstalling the optical drive, be sure that the drive tray is out far enough to slide under the lower casing rim.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Modem: stap 20, afbeelding 1 van 1
      • Remove the following Phillips screws:
      • Remove the longer Phillips screw from the middle-rear of the modem shield.
      • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
      • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
      • Remove the EMI fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 21, afbeelding 1 van 1
      • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 22, afbeelding 1 van 1
      • Remove the Phillips screw from the left side of the modem.
      • Pry up the right side of the modem.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell Hard Drive Replacement: stap 23, afbeelding 1 van 1
      • Lift the modem partially out and disconnect the cable on the left side.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Display: stap 24, afbeelding 1 van 1
      • Remove the Phillips screw from the left hinge.
      • Peel up the airport cable from beneath the yellow tape.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 25, afbeelding 1 van 1
      • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 26, afbeelding 1 van 1
      • Disconnect the backlight cable from the logic board and deroute it.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell Hard Drive Replacement: stap 27, afbeelding 1 van 1
      • Remove the three small Phillips screws from the clutch cover.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 Clamshell Hard Drive Replacement: stap 28, afbeelding 1 van 1
      • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
      • Remove the display assembly.
      • When re-installing the display assembly, make sure that the clutch cover goes over the white plastic tabs protruding from the rear underside of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, EMI Shield: stap 29, afbeelding 1 van 1
      • Remove the two small Phillips screws from the RJ-11 board.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 30, afbeelding 1 van 1
      • Push out the lower case rim and pull the RJ-11 board out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell Hard Drive Replacement: stap 31, afbeelding 1 van 1
      • Deroute the speaker cable from the metal framework and disconnect it from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell Hard Drive Replacement: stap 32, afbeelding 1 van 1
      • There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
      • Two short, flat-headed Phillips screws near the battery compartment.
      • One short, round-headed Phillips near the speaker cable connector. (This is present on some models, but not others - especially the older ones)
      • One short, flat-headed Phillips between the ethernet and USB ports.
      • One short, flat-headed Phillips to the left of the hole-y (polite laughter) area.
      • One long, round-headed Phillips screw near the power receptacle.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 Clamshell Hard Drive Replacement: stap 33, afbeelding 1 van 1
      • Lift the right side of the EMI shield up and pull it out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Hard Drive: stap 34, afbeelding 1 van 1
      • Remove the three 5 mm standoffs securing the hard drive to the logic board.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell Hard Drive Replacement: stap 35, afbeelding 1 van 1
      • Pull the hard drive cable up from the logic board, using the plastic loop.
      • Lift the hard drive, with metal bracket attached, from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell Hard Drive Replacement, Hard Drive: stap 36, afbeelding 1 van 1
      • Take the metal bracket away from the hard drive.
      • Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself.
      • This is a bit tricky. Try holding the drive against your body while pushing the cable away from you, or rocking the cable gently from side to side while applying even pressure, or both. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
84 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
9Gids Commentaar
after several assembly and disassemblies I found an SSD solution that works - essentially a PATA/EID to SD card adaptor from ebay (china source) for a few bucks and then I used carbon copy cloner to image and clone the active 6GB disk. My failed attempts involved 32GB SSD from Kingspan - would not boot (with any Jumper setting - very frustrating with a 30min each assemble/disassemble to test!)
James Field - Antwoord Deel
Hi, thanks for the SD card adapter suggestion. Super helpful. Are you able to provide a link or item name please for the adapter? Thank you.
Dale Sorenson - Antwoord Deel
James Field, I really wonder how fast an SSD actually is (compared to the initial setup) when using MacOS X 10.1 or so, with a G3 processor.
freed - Antwoord Deel
Great guide, I followed to the end. I swapped out my drive for a compact flash adapter and a 16GB card. My Clamshell runs absolutely silently. I’m hoping this will extend the battery life, too.
One thing I noticed when putting the display back on is the segment between the joints had to fit on to some hooks on the lower part of the case. That allowed the tiny screw holes between the joints to line up nicely.
Mr Poofy - Antwoord Deel
Made the mistake of not fitting these hooks on the lower part of the case before finishing disassembly - I was wondering why the clutch cover was so difficult to re-attach, and this was the culprit. Thanks for this comment
[deleted] - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 210
Altijd: 65,814
