Ga door naar hoofdinhoud
iBook G3 Clamshell DC-In Board Replacement
Wat je nodig hebt
    1. iBook G3 Clamshell DC-In Board Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, Airport Card: stap 2, afbeelding 1 van 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 3, afbeelding 1 van 1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 4, afbeelding 1 van 1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, Keyboard: stap 5, afbeelding 1 van 1
      • Remove the two Phillips screws that secure the RAM shield.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 6, afbeelding 1 van 1
      • Grasp the wire metal bracket on top of the RAM shield and pull upward to remove the shield.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 7, afbeelding 1 van 1
      • Pull up the keyboard connector cable by its clear plastic loop.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, Upper Case: stap 8, afbeelding 1 van 1
      • Use a straightened paperclip to manually eject the CD-ROM tray.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 9, afbeelding 1 van 1
      • Turn the computer over so that the bottom is facing up.
      • Remove the following Torx screws:
      • Four short T8 Torx near the battery compartment.
      • Two long T8 Torx near the hinges.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 10, afbeelding 1 van 1
      • Pull the CD-ROM drive tray partly out.
      • Remove the silver Phillips screw from the plastic casing.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell DC-In Board Replacement: stap 11, afbeelding 1 van 1
      • Turn the computer over.
      • Remove the three Phillips screws.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 Clamshell DC-In Board Replacement: stap 12, afbeelding 1 van 1
      • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Vraag FixBot
      Voeg opmerking toe
    6. iBook G3 Clamshell DC-In Board Replacement: stap 13, afbeelding 1 van 1
      • Loosen the trackpad clamp by pulling the top piece up slightly, freeing the trackpad ribbon.
      • Slide the orange trackpad ribbon out of the clamp.
      Vraag FixBot
      Voeg opmerking toe
    7. iBook G3 Clamshell DC-In Board Replacement: stap 14, afbeelding 1 van 1
      • Do not lift the upper case too far without first disconnecting the audio cable.
      • Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
      • Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
      Vraag FixBot
      Voeg opmerking toe
    8. iBook G3 Clamshell DC-In Board Replacement: stap 15, afbeelding 1 van 1
      • Disconnect the audio cable.
      Vraag FixBot
      Voeg opmerking toe
    9. iBook G3 Clamshell DC-In Board Replacement: stap 16, afbeelding 1 van 1
      • Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
      • You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, Optical Drive: stap 17, afbeelding 1 van 1
      • If the optical drive is not open, use a straightened paperclip to open it now.
      • Remove the 5 mm standoff.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 18, afbeelding 1 van 1
      • Disconnect the optical drive cable from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 19, afbeelding 1 van 1
      • Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
      • Lift up the side of the optical drive you just freed and slide the drive out and away from the screen.
      • When reinstalling the optical drive, be sure that the drive tray is out far enough to slide under the lower casing rim.
      • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, Modem: stap 20, afbeelding 1 van 1
      • Remove the following Phillips screws:
      • Remove the longer Phillips screw from the middle-rear of the modem shield.
      • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
      • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
      • Remove the EMI fingers.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 21, afbeelding 1 van 1
      • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 22, afbeelding 1 van 1
      • Remove the Phillips screw from the left side of the modem.
      • Pry up the right side of the modem.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell DC-In Board Replacement: stap 23, afbeelding 1 van 1
      • Lift the modem partially out and disconnect the cable on the left side.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, Display: stap 24, afbeelding 1 van 1
      • Remove the Phillips screw from the left hinge.
      • Peel up the airport cable from beneath the yellow tape.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 25, afbeelding 1 van 1
      • Disconnect the large display data cable from the logic board and deroute it from the plastic and metal tabs.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 26, afbeelding 1 van 1
      • Disconnect the backlight cable from the logic board and deroute it.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell DC-In Board Replacement: stap 27, afbeelding 1 van 1
      • Remove the three small Phillips screws from the clutch cover.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 Clamshell DC-In Board Replacement: stap 28, afbeelding 1 van 1
      • Finally, support the display with one hand while unscrewing the last Phillips screw from the right hinge (push the display gently down to avoid putting pressure on the screw).
      • Remove the display assembly.
      • When re-installing the display assembly, make sure that the clutch cover goes over the white plastic tabs protruding from the rear underside of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, EMI Shield: stap 29, afbeelding 1 van 1
      • Remove the two small Phillips screws from the RJ-11 board.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 Clamshell DC-In Board Replacement: stap 30, afbeelding 1 van 1
      • Push out the lower case rim and pull the RJ-11 board out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 Clamshell DC-In Board Replacement: stap 31, afbeelding 1 van 1
      • Deroute the speaker cable from the metal framework and disconnect it from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 Clamshell DC-In Board Replacement: stap 32, afbeelding 1 van 1
      • There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
      • Two short, flat-headed Phillips screws near the battery compartment.
      • One short, round-headed Phillips near the speaker cable connector. (This is present on some models, but not others - especially the older ones)
      • One short, flat-headed Phillips between the ethernet and USB ports.
      • One short, flat-headed Phillips to the left of the hole-y (polite laughter) area.
      • One long, round-headed Phillips screw near the power receptacle.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 Clamshell DC-In Board Replacement: stap 33, afbeelding 1 van 1
      • Lift the right side of the EMI shield up and pull it out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 Clamshell DC-In Board Replacement, DC-In Board: stap 34, afbeelding 1 van 1
      • Push down firmly on the logic board and pull the DC-In board up from its connectors and then to the left.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 63
Altijd: 11,814
