Ga door naar hoofdinhoud
iBook G3 14" RAM Replacement
Wat je nodig hebt
    1. iBook G3 14" RAM Replacement, Battery: stap 1, afbeelding 1 van 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 14" RAM Replacement, Keyboard: stap 2, afbeelding 1 van 1
      • Pull the keyboard release tabs (highlighted in red) toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      Vraag FixBot
      Voeg opmerking toe
    2. iBook G3 14" RAM Replacement: stap 3, afbeelding 1 van 1
      • If your computer does not have an AirPort card installed, skip to the RAM shield removal step.
      • Push the wire clasp toward the AirPort card and pull it up to free it from the RAM shield.
      Vraag FixBot
      Voeg opmerking toe
    3. iBook G3 14" RAM Replacement: stap 4, afbeelding 1 van 1
      • Grasp the clear plastic tab on the AirPort card and pull toward the right.
      Vraag FixBot
      Voeg opmerking toe
    4. iBook G3 14" RAM Replacement: stap 5, afbeelding 1 van 1
      • Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
      Vraag FixBot
      Voeg opmerking toe
    5. iBook G3 14" RAM Replacement: stap 6, afbeelding 1 van 1
      • Remove the two Phillips screws that secure the RAM shield.
      Vraag FixBot
      Voeg opmerking toe
    6. iBook G3 14" RAM Replacement: stap 7, afbeelding 1 van 1
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      Vraag FixBot
      Voeg opmerking toe
    7. iBook G3 14" RAM Replacement: stap 8, afbeelding 1 van 1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      Vraag FixBot
      Voeg opmerking toe
    1. iBook G3 14" RAM Replacement, RAM: stap 9, afbeelding 1 van 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
11 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 61
Altijd: 29,978
