Ga door naar hoofdinhoud
iBook G3 12" DC-In Board Replacement
Wat je nodig hebt
  1. iBook G3 12" DC-In Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  2. iBook G3 12" DC-In Board Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
    Vraag FixBot
    Voeg opmerking toe
  3. iBook G3 12" DC-In Board Replacement: stap 3, afbeelding 1 van 1
    • If the computer does not have an Airport card installed, skip the next two steps.
    • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
    Vraag FixBot
    Voeg opmerking toe
  4. iBook G3 12" DC-In Board Replacement: stap 4, afbeelding 1 van 1
    • Grasp the clear plastic tab on the Airport card and pull toward the right.
    Vraag FixBot
    Voeg opmerking toe
  5. iBook G3 12" DC-In Board Replacement: stap 5, afbeelding 1 van 1
    • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
    Vraag FixBot
    Voeg opmerking toe
  6. iBook G3 12" DC-In Board Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
    Vraag FixBot
    Voeg opmerking toe
  7. iBook G3 12" DC-In Board Replacement: stap 7, afbeelding 1 van 1
    • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
    Vraag FixBot
    Voeg opmerking toe
  8. iBook G3 12" DC-In Board Replacement: stap 8, afbeelding 1 van 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    Vraag FixBot
    Voeg opmerking toe
  9. iBook G3 12" DC-In Board Replacement, Lower Case: stap 9, afbeelding 1 van 1
    • Your laptop should look approximately like this.
    Vraag FixBot
    Voeg opmerking toe
  10. iBook G3 12" DC-In Board Replacement: stap 10, afbeelding 1 van 1
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    Vraag FixBot
    Voeg opmerking toe
  11. iBook G3 12" DC-In Board Replacement: stap 11, afbeelding 1 van 1
    • Remove the three 5.2 mm newly-revealed Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  12. iBook G3 12" DC-In Board Replacement: stap 12, afbeelding 1 van 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    Vraag FixBot
    Voeg opmerking toe
  13. iBook G3 12" DC-In Board Replacement: stap 13, afbeelding 1 van 1
    • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
    Vraag FixBot
    Voeg opmerking toe
  14. iBook G3 12" DC-In Board Replacement: stap 14, afbeelding 1 van 1
    • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
    Vraag FixBot
    Voeg opmerking toe
  15. iBook G3 12" DC-In Board Replacement: stap 15, afbeelding 1 van 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    Vraag FixBot
    Voeg opmerking toe
  16. iBook G3 12" DC-In Board Replacement: stap 16, afbeelding 1 van 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    Vraag FixBot
    Voeg opmerking toe
  17. iBook G3 12" DC-In Board Replacement: stap 17, afbeelding 1 van 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    Vraag FixBot
    Voeg opmerking toe
  18. iBook G3 12" DC-In Board Replacement: stap 18, afbeelding 1 van 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    Vraag FixBot
    Voeg opmerking toe
  19. iBook G3 12" DC-In Board Replacement: stap 19, afbeelding 1 van 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    Vraag FixBot
    Voeg opmerking toe
  20. iBook G3 12" DC-In Board Replacement: stap 20, afbeelding 1 van 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    Vraag FixBot
    Voeg opmerking toe
  21. iBook G3 12" DC-In Board Replacement, Bottom Shield: stap 21, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  22. iBook G3 12" DC-In Board Replacement: stap 22, afbeelding 1 van 1
    • Remove the five 5.8 mm Phillips screws from the bottom shield.
    • Peel back the yellow tape and foil shielding outlined in the image.
    Vraag FixBot
    Voeg opmerking toe
  23. iBook G3 12" DC-In Board Replacement: stap 23, afbeelding 1 van 1
    • Lift the bottom shield off.
    Vraag FixBot
    Voeg opmerking toe
  24. iBook G3 12" DC-In Board Replacement, Upper Case: stap 24, afbeelding 1 van 1
    • Remove the following 4 screws on the bottom of the computer:
    • Two 3 mm Phillips from the left side of the computer.
    • One 4.5 mm Phillips near the latch mechanism (this screw may be missing in 800 MHz iBooks)
    • One 14.2 mm Phillips near the front, right corner.
    Vraag FixBot
    Voeg opmerking toe
  25. iBook G3 12" DC-In Board Replacement: stap 25, afbeelding 1 van 1
    • Use a straightened paperclip to open the optical drive tray.
    Vraag FixBot
    Voeg opmerking toe
  26. iBook G3 12" DC-In Board Replacement: stap 26, afbeelding 1 van 1
    • Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  27. iBook G3 12" DC-In Board Replacement: stap 27, afbeelding 1 van 1
    • Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
    Vraag FixBot
    Voeg opmerking toe
  28. iBook G3 12" DC-In Board Replacement: stap 28, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Turn over the computer and open it.
    • Use tweezers (or a refrigerator magnet) to remove the magnet covering a Phillips screw near the middle of the computer.
    Vraag FixBot
    Voeg opmerking toe
  29. iBook G3 12" DC-In Board Replacement: stap 29, afbeelding 1 van 1
    • Remove the following 4 screws on the edges of the keyboard area.
    • One 4.5 mm Phillips underneath where the magnet was.
    • Three 6 mm Phillips in plastic depressions.
    Vraag FixBot
    Voeg opmerking toe
  30. iBook G3 12" DC-In Board Replacement: stap 30, afbeelding 1 van 1
    • Peel up the foil tape covering the speaker cable near the ports.
    Vraag FixBot
    Voeg opmerking toe
  31. iBook G3 12" DC-In Board Replacement: stap 31, afbeelding 1 van 1
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Vraag FixBot
    Voeg opmerking toe
  32. iBook G3 12" DC-In Board Replacement: stap 32, afbeelding 1 van 1
    • Loosen the trackpad connector by pulling the top piece up slightly, freeing the trackpad ribbon.
    • Slide the orange trackpad ribbon out of the connector.
    Vraag FixBot
    Voeg opmerking toe
  33. iBook G3 12" DC-In Board Replacement: stap 33, afbeelding 1 van 1
    • Before you can jerk the upper case off with joy, you must disconnect both the blue and white power cable and red and black speaker cable as described in the next steps.
    • Lift the upper case from the left side and use your other hand to pull out the right side in order to clear the power receptacle.
    • There may be a thin metal bar fastened to the upper case by the two screws on either side of the optical drive. This bar provides rigidity around the optical drive; don't forget it when reassembling.
    Vraag FixBot
    Voeg opmerking toe
  34. iBook G3 12" DC-In Board Replacement: stap 34, afbeelding 1 van 1
    • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
    • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
    Vraag FixBot
    Voeg opmerking toe
  35. iBook G3 12" DC-In Board Replacement: stap 35, afbeelding 1 van 1
    • Lift the upper case off completely and disconnect the red and black speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
    Vraag FixBot
    Voeg opmerking toe
  36. iBook G3 12" DC-In Board Replacement: stap 36, afbeelding 1 van 1
    • There is a magnet that allows the computer to detect when the laptop is closed. If this magnet is not present your computer will not automatically go to sleep. Be sure the magnet is in the position indicated.
    Vraag FixBot
    Voeg opmerking toe
  37. iBook G3 12" DC-In Board Replacement, Top Shield: stap 37, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  38. iBook G3 12" DC-In Board Replacement: stap 38, afbeelding 1 van 1
    • Remove the following 14 screws (some models may be missing a couple of screws):
    • One 2.5 mm Phillips.
    • Six 3.5 mm Phillips.
    • One 4.5 mm Phillips near the sleep light with a small shaft.
    • Two 4.5 mm Phillips with larger shafts.
    • Four 5 mm Phillips
    • If a screw is inserted in the left hole, the 14.2 mm screw in step 24 can not be inserted to hold the top case down.
    Vraag FixBot
    Voeg opmerking toe
  39. iBook G3 12" DC-In Board Replacement: stap 39, afbeelding 1 van 1
    • Peel back three strips of yellow tape in the bottom left corner.
    • Peel back one strip of foil tape in the upper left corner and another near where the trackpad connects to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  40. iBook G3 12" DC-In Board Replacement: stap 40, afbeelding 1 van 1
    • Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
    Vraag FixBot
    Voeg opmerking toe
  41. iBook G3 12" DC-In Board Replacement, Optical Drive: stap 41, afbeelding 1 van 1
    • If you have already removed the hard drive or display in a previous step, your iBook may differ slightly from the picture.
    • On the bottom of the computer, disconnect the DC-In cable from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  42. iBook G3 12" DC-In Board Replacement: stap 42, afbeelding 1 van 1
    • Flip the computer over and open the display.
    • Open the optical drive using a straightened paperclip (if it's not already opened).
    • Peel up the yellow tape from the optical drive.
    Vraag FixBot
    Voeg opmerking toe
  43. iBook G3 12" DC-In Board Replacement: stap 43, afbeelding 1 van 1
    • This step may vary on some iBook models. If the screws shown are not on your iBook, you may need to flip the computer over and remove two screws attaching the bottom of the optical drive to the metal framework.
    • Remove the two Phillips screws securing the optical drive to the metal framework.
    Vraag FixBot
    Voeg opmerking toe
  44. iBook G3 12" DC-In Board Replacement: stap 44, afbeelding 1 van 1
    • Peel back the orange ribbon cable to reveal a single Phillips screw. Remove this screw to free the optical drive from the metal framework.
    Vraag FixBot
    Voeg opmerking toe
  45. iBook G3 12" DC-In Board Replacement: stap 45, afbeelding 1 van 1
    • Lift the optical drive by the edge closest to the screen, minding that the metal bracket at the top left corner doesn't catch on the Airport or inverter cables.
    Vraag FixBot
    Voeg opmerking toe
  46. iBook G3 12" DC-In Board Replacement: stap 46, afbeelding 1 van 1
    • Remove the two 2.5 mm Phillips screws securing the large orange ribbon cable and thin metal bracket to the drive.
    Vraag FixBot
    Voeg opmerking toe
  47. iBook G3 12" DC-In Board Replacement: stap 47, afbeelding 1 van 1
    • Disconnect the ribbon cable from the optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
    Vraag FixBot
    Voeg opmerking toe
  48. iBook G3 12" DC-In Board Replacement, DC-In Board: stap 48, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  49. iBook G3 12" DC-In Board Replacement: stap 49, afbeelding 1 van 1
    • Remove the single 5.5 mm Phillips screw securing the DC-In board to the metal framework.
    Vraag FixBot
    Voeg opmerking toe
  50. iBook G3 12" DC-In Board Replacement: stap 50, afbeelding 1 van 1
    • Peel up the DC-In cable from the bottom of the metal framework and pull it through the conveniently-located nearby hole.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
18 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
1Gids Commentaar
What was the symptom(s) leading to the diagnosis that this board was in need of being replaced??
Ken Kappler - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 90
Altijd: 33,749
