Ga door naar hoofdinhoud
iBook G3 12" Bottom Shield Replacement
Wat je nodig hebt
  1. iBook G3 12" Bottom Shield Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  2. iBook G3 12" Bottom Shield Replacement, Lower Case: stap 2, afbeelding 1 van 1
    • Your laptop should look approximately like this.
    Vraag FixBot
    Voeg opmerking toe
  3. iBook G3 12" Bottom Shield Replacement: stap 3, afbeelding 1 van 1
    • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
    Vraag FixBot
    Voeg opmerking toe
  4. iBook G3 12" Bottom Shield Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 5.2 mm newly-revealed Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  5. iBook G3 12" Bottom Shield Replacement: stap 5, afbeelding 1 van 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
    Vraag FixBot
    Voeg opmerking toe
  6. iBook G3 12" Bottom Shield Replacement: stap 6, afbeelding 1 van 1
    • Remove the one 10 mm and two 20 mm hex screws using a 2mm hex. Alternatively, a T8 Torx screwdriver key will do.
    Vraag FixBot
    Voeg opmerking toe
  7. iBook G3 12" Bottom Shield Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 4.2 mm Phillips screws on either side of the battery contacts.
    Vraag FixBot
    Voeg opmerking toe
  8. iBook G3 12" Bottom Shield Replacement: stap 8, afbeelding 1 van 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
    Vraag FixBot
    Voeg opmerking toe
  9. iBook G3 12" Bottom Shield Replacement: stap 9, afbeelding 1 van 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
    Vraag FixBot
    Voeg opmerking toe
  10. iBook G3 12" Bottom Shield Replacement: stap 10, afbeelding 1 van 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
    Vraag FixBot
    Voeg opmerking toe
  11. iBook G3 12" Bottom Shield Replacement: stap 11, afbeelding 1 van 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
    Vraag FixBot
    Voeg opmerking toe
  12. iBook G3 12" Bottom Shield Replacement: stap 12, afbeelding 1 van 1
    • Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
    Vraag FixBot
    Voeg opmerking toe
  13. iBook G3 12" Bottom Shield Replacement: stap 13, afbeelding 1 van 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
    Vraag FixBot
    Voeg opmerking toe
  14. iBook G3 12" Bottom Shield Replacement, Bottom Shield: stap 14, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  15. iBook G3 12" Bottom Shield Replacement: stap 15, afbeelding 1 van 1
    • Remove the five 5.8 mm Phillips screws from the bottom shield.
    • Peel back the yellow tape and foil shielding outlined in the image.
    Vraag FixBot
    Voeg opmerking toe
  16. iBook G3 12" Bottom Shield Replacement: stap 16, afbeelding 1 van 1
    • Lift the bottom shield off.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
11 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
iRobot
1 Reputatie
636 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 50
Altijd: 9,204
