Ga door naar hoofdinhoud
Garmin Avionics Wiring Termination
Engels
Nederlands
Stap 12 vertalen
Stap 12
Garmin Avionics Wiring Termination, Shield Termination: stap 0, afbeelding 1 van 1
Shield Termination
  • Crimp ring terminal to shield braid
  • Install ring terminal to designated grounding location. Often the connector back-shell.
  • This step is done last after all wires for a connector are installed and back-shell is assembled on connector. Sometimes a separate ground lug needs to be installed onto the back-shell.
Vertaling hier toevoegen
