Inleiding
This is where all of the power comes into the device. Learn how to replace it. Be careful while soldering!
Wat je nodig hebt
Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Locate the three solder connections for the electrical port.
Desolder the connection points following the instructions included with your soldering kit as you remove the port.
Één andere persoon heeft deze handleiding voltooid.
