Inleiding
Before removing and replacing the sensor of Zoomer Dino Boomer, check the Troubleshooting Page to make sure the issue with gesture mode cannot be fixed without removing the sensor.
Wat je nodig hebt
Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
Bijna klaar!
Conclusie
