Ga door naar hoofdinhoud
Zoom H1 Handy Recorder Battery Terminal Replacement
Wat je nodig hebt
  1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: stap 1, afbeelding 1 van 1
    • Place the device so the display is down.
  2. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 4, afbeelding 1 van 1
    • Carefully pry up the top end of the back cover using one finger
    There is a third screw right next to the serial number sticker on mine.
    Ricardo Teixeira - Antwoord
    Same comment here, 3rd screw not to be forgotten.
    yves debacker - Antwoord
  5. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 5, afbeelding 1 van 1
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  6. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 6, afbeelding 1 van 1
    • De-solder at terminal point one.
  7. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 7, afbeelding 1 van 1
    • De-solder at the second terminal point.
  8. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 8, afbeelding 1 van 2 Zoom H1 Handy Recorder Battery Terminal Replacement: stap 8, afbeelding 2 van 2
    • Remove the faulty terminals
  9. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 9, afbeelding 1 van 1
    • Place new lead in at point one and re-solder at the point.
  10. Zoom H1 Handy Recorder Battery Terminal Replacement: stap 10, afbeelding 1 van 1
    • Place second lead at point 2 and re-solder.
Conclusie
To Re-construct device, perform these steps in reverse order.
Alex
809 Reputatie
5 handleidingen geschreven
7 opmerkingen
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Antwoord
Mine has third screw under the serial-number sticker.
halluciana - Antwoord
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Antwoord
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Antwoord
Same problem, without any reason it is dead
eevilcute -
Where can i find the replacement battery terminals?
krissie_prime - Antwoord
My zoom h1 just dead exactly after 2 years with no reason. It doesn’t turn on. The battery terminals are in good condition. Any ideas?
btw yes there is a third screw under the serial-number sticker.
Paco Raya Morales - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 6,382
