Ga door naar hoofdinhoud
Zerodate T26 Main Clicker Replacement
Wat je nodig hebt
  1. Zerodate T26 Main Clicker Replacement, Scroll Wheel: stap 1, afbeelding 1 van 2 Zerodate T26 Main Clicker Replacement, Scroll Wheel: stap 1, afbeelding 2 van 2
    • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
  2. Zerodate T26 Main Clicker Replacement: stap 2, afbeelding 1 van 2 Zerodate T26 Main Clicker Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
    • Adhesive pads are located on the bottom of the mouse.
  3. Zerodate T26 Main Clicker Replacement: stap 3, afbeelding 1 van 2 Zerodate T26 Main Clicker Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
  4. Zerodate T26 Main Clicker Replacement: stap 4, afbeelding 1 van 2 Zerodate T26 Main Clicker Replacement: stap 4, afbeelding 2 van 2
    • Carefully pull the middle shell apart from the bottom plate.
    • The circuit board should then be visible and attached to the bottom plate.
  5. Zerodate T26 Main Clicker Replacement: stap 5, afbeelding 1 van 2 Zerodate T26 Main Clicker Replacement: stap 5, afbeelding 2 van 2
    • Remove the scroll wheel by pushing it to the right and pulling up.
  6. Zerodate T26 Main Clicker Replacement, Main Clicker: stap 6, afbeelding 1 van 1
    • If the switches themselves are the issue, first dip a Q-tip into some isopropyl alcohol and rub it into and around the white switches. This should remove any dirt or debris that is impeding the operation of the switch.
    • The red switch seen in this image would otherwise be covered by the scroll wheel.
  7. Zerodate T26 Main Clicker Replacement: stap 7, afbeelding 1 van 1
    • If the switches still do not work, then they need to be replaced. Mouse clicker switches can be purchased online, please refer to this soldering guide for the steps needed to remove and replace these switches.
    • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove clicker switches.
Conclusie
Janice Rullan
662 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 2-3, Petersen Spring 2023 Lid van UMass Dartmouth, Team 2-3, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 128
