Ga door naar hoofdinhoud
Zeki TBQG884B Motherboard Replacement
Wat je nodig hebt
  1. Zeki TBQG884B Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 2 Zeki TBQG884B Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Motherboard Replacement: stap 3, afbeelding 1 van 2 Zeki TBQG884B Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Disconnect the Wi-Fi antenna cable from the motherboard.
  5. Zeki TBQG884B Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
  6. Zeki TBQG884B Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
  7. Zeki TBQG884B Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the other ZIF connector on the opposite side of the motherboard.
  8. Zeki TBQG884B Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the motherboard and now reinsert all connectors into a new motherboard.
    • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
Conclusie
Linlin Cai
317 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-3, Harley Fall 2015 Lid van IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 506
